LED Headlights installed PICS!
#31
Ok, so had a quick look earlier... first thing i need to do is remove the upper chrome grille. Problem is, I didn't know where all the bolts were. I can see the 2x 10mm bolts at either end of the grill (corners) they're fine, but can anyone point me to the other two ? I am thinking i can take the upper grill and bottom grill off in one go, and then have better access to the lower grill as the clips are rusted, and i want to install a brushguard at the same time...
Anyone got a pic where i should be looking ??
I did see two nuts through the upper grill when the hood was closed, are these the ones i need to remove ?
#32
I sorted it in the end so no probs... regarding the trucklites, i got them and installed. First thing for anyone looking:
a) i didn't need to sand anything down on the back of the light housing. The trucklite fit as a direct replacement with no problems at all.
b) i also bought the trucklite pulse adaptor (to remove the flickering) however the existing hummer connection didn't fit the same connector that was on so i had to cut and splice (a little bit ghetto!) but worked ok.
c) I bought the 27270C, and i can confirm that I do see some kind of X pattern at the end of the beams. To be honest, this doesnt bother me in the slightest, and it only really becomes apparent if you're say facing a brick wall. On the road (including dark empty highway), i don't notice it.
d) I think I will probably need to align them. I don't quite know how to do this yet, so if anyone has any ideas (horizontal and vertical) am all ears!
#34
Excuse the iPhone quality. Didn't want to take the big camera out!
The lights are basically parked (low beam) - huge improvement over the previous ones. I have to be mindful that the LEDs don't put the heat out so they could get covered in ice/snow more which I need to be mindful of but the benefits of proper lighting outweighs this for me.
Decent upgrade at a decent price. Thanks to LoJack for his guidance.
#39
The white electrical tape is covering some electrical connector blocks where i needed to "ghetto" the hummer wires to the wires of the anti flickering module. I bought the modules and the lamps on amazon. Well pleased with them. I don't even notice the "x" pattern now, i just know i can see a lot more at night. Even in the middle of a moscow winter with all the slush and salt on the roads, they're holding up well.
#40
Has anyone ever installed this? Looks so cool!
7" Round Chrome LED Halo Projector Headlights Conversion Kit H4 H6014 H6015 CM13 | eBay
