Leak?
Old 09-27-2010, 03:42 PM
h2!'s Avatar
h2!
h2! is offline
Default Leak?
Has anyone had trouble with water leaking from the roof console around the sunroof control and garage opener controls. I thought that maybe the sunroof was leaking but the sunroof doesnt even go up that far and the tracks of the sunroof are bone dry.
Old 09-27-2010, 04:14 PM
olfart's Avatar
do a search in this forum for "leaks". You'll fing plenty of threads. First place to look would be the roof marker lights.
________
Threesome Fetish
Old 09-27-2010, 06:25 PM
giant H2's Avatar
olfarts probably right i thought that my window was leaking and it was the marker lights. Take them off and re-seal them with marine silicone sealant
Old 09-27-2010, 06:49 PM
hillbilly's Avatar
Same thing here pulled off the marker lights and sealed under them and the water stopped
Old 09-28-2010, 07:34 AM
DTS62284's Avatar
I had the same issue as Hillbilly it probably your marker lights.
Old 09-29-2010, 07:49 AM
Roof marker seals or sunroof drains are the usual culprits.. J
Old 09-30-2010, 02:43 PM
CiscoH2's Avatar
I had the same problem. Front roof markers need gaskets resealed. You can try to fit a new gasket but good luck and hummer only sells you the entire marker kit $$$$$$$.
Old 09-30-2010, 04:17 PM
olfart's Avatar
Also check under the marker light. The rubber grommet where the wires pass down into the door column usually comes loose and leaks. Clean and reseal with adhesive RTV
________
VAPIR ONE BAGS
tls 14
05-11-2023 08:13 AM
RickLF
07-03-2008 07:16 AM
RealJeep
08-23-2007 01:38 PM
JDJoe
04-28-2007 03:20 PM
iruffneck
17
03-04-2006 01:33 AM
Quick Reply: Leak?
