Largest Tires for H2, on Stock roms with no lift...
Old 04-25-2007, 07:22 PM
CDiPrecision's Avatar
Default Largest Tires for H2, on Stock roms with no lift...
Title Sez it all... the tires forum is all only H3 guys and tire topics.. nothing for H2's in there. I have the stockers on there now I think(BFG 315 series tires)..
I dont want rubbing issues, nor to have to lift it..
Old 04-25-2007, 07:30 PM
ZYNE's Avatar
Default RE: Largest Tires for H2, on Stock roms with no lift...
I believe if you crank your torsion bars a couple of turnsyou can fit 37's with little or no rubbin ... If you don't I think they will definitely rub a bit ... Shorty .. you run 37's on yours .. chime in here bro .. though if I recall .. you have aftermarket rims .... what's the difference, if any, in offset??
Old 04-25-2007, 08:47 PM
shortbus's Avatar
i run 37's on aftermarket steel rims. i have no idea what the offset is, i just said i wanted "these rims and those tires" and they made it happen. i have rubbing on the back fenderwell when i'm turned full crank, but that's because they're 13.5" wide. the only other rubbing is from coming down on the front end a bit harder than i should, or when i'm really deep in a rut on one side. same thing on the back ones, the articulation can push the tire up into the wheel well and rip out the screws that hold on the plastic inner fender well (oops).not sure this helps much, but it's all i got.
sonicsbomb
04-22-2021 09:46 PM
gowpowdsp
08-17-2012 09:16 AM
Landbruiser69
01-27-2011 07:40 PM
BajaH3T
12-29-2009 04:54 PM
Nxsov180db
06-02-2008 01:38 PM
Quick Reply: Largest Tires for H2, on Stock roms with no lift...
