key stuck in ignition
Old 03-02-2010, 02:15 PM
lbzvegas082's Avatar
Default key stuck in ignition
Anyone have this happen? I read the post on what to do to get the key out, that was helpful, but having to use a screwdriver to get the key out of the ignition every time is annoying. Also it will shift through the gears without the brake pressed. No broken wires under dash, no battery drain, just the problems mentioned above. Anyone had this problem or have any ideas?
Old 03-02-2010, 06:39 PM
vetteman40404's Avatar
Just put a squirt of WD-40 inside the ignition lock, then work the key in and out a few times.
Old 03-03-2010, 01:12 AM
Didn't work. I can hear and feel it locking the key in the ignition as soon as I turn it past the off position. Doesn't explain it shifting without the brake applied either. I am thinking brake switch, ignition switch, or something else. Would like to target the problem instead of replacing everything related to it.
Old 03-03-2010, 10:11 AM
No more Jeeps's Avatar
New switch. Several H2s that I have looked at buying show on the carfax that the ignition switch has been replaced. Must be a common problem...
nncanfarelli
08-04-2019 09:27 PM
hummerhonduras
42
09-19-2012 11:49 AM
lbzvegas082
07-21-2010 07:17 PM
ezspirit
06-29-2009 07:13 AM
doyleh3
04-02-2008 10:01 PM
Quick Reply: key stuck in ignition
