Key fob drains all batteries
Old 01-15-2012, 04:59 PM
Cashville's Avatar
Default Key fob drains all batteries
My key fob is draining all batteries, I've tried different brand batteries but it drains them withing 2 weeks max...
I've also tried one battery I had on my other key fob that has been working perfectly for months, switched it to the faulty keyfob, and after 1 week, the battery died.
anyone know of any solution for this?
Old 01-15-2012, 08:21 PM
drtom's Avatar
Banned
is it working normal otherwise?
tricky to work on but with almost any digital meter you could check for leakage current .
should be no current till a button is pushed,then a constant current while pushed,VERY LOW,in microamps i guess.
the testers on the counter at a/z show activity as long as button is pushed. so it is on as long as button is pushed.
more when i get it. im curious! how much current
later,
well,more than i thought,but it is a transmitter. its appx 900 microamps,or just under a milliamp. one thousandth of a amp at 3 volts.
so,if you read ANYTHING,its got leakage. maybe an alcohol scrub? but without checking leakage you can only feed it xpensive batts.
btw the dollar store sometimes has a card full,cheep.
its really a 2 guy job ,4 hands.to get a meter,and the batt connected,tricky indeed. i used tiny clips and a power supply.
i cant tell u how till u get it apart which also is tricky, sharp knife,,,no blood yet!
Old 01-15-2012, 11:17 PM
Cashville's Avatar
I've got a multimeter, can that be used to see if there is any leakage? If yes, what option on the multimeter should I choose?
Old 01-16-2012, 06:52 AM
drtom's Avatar
Banned
is it working normal otherwise?....all buttons
Old 01-16-2012, 03:18 PM
Cashville's Avatar
yes, all buttons are working with no problems...
Old 01-16-2012, 05:57 PM
mattdillon's Avatar
Man, I've never heard of that before but I guess it could! Good Luck, let us know how it ends.
Old 01-16-2012, 06:13 PM
drtom's Avatar
Banned
so pop it open,with a SHARP object, no fair bleeding,scrub with isoprople ?? alcohol and or look for crud.
dont know what else
Old 01-16-2012, 09:02 PM
Cashville's Avatar
I don't have the remote with me. I'll clean it up with some alcohol and take some pictures so you can take a look and see if you can detect anything out of the ordinary..
Old 01-17-2012, 12:29 PM
Cashville's Avatar
Here are some pics. Don't mind the battery, its a cheap pack I got from ebay, they are chinese, but I have also tried Maxell and Energizer, and they all get drained...
Old 01-17-2012, 08:57 PM
stevek813's Avatar
I don't want to state the obvious but can't you just order a replacement? Seems to me that might be easier than fooling around trying to figure out what's wrong with the one you have.
Then again, I am talking out of my ear because I don't know how the heck much these things cost. I've had a remote for my various cars for the past 15 or 16 years and I've never even had to change a battery before.
Please do let us know how it ends for you. I would also like to know how much one of those darn things cost.
Quick Reply: Key fob drains all batteries
