Key does not come out unless brake pedal applied
Old 08-17-2016, 09:20 AM
Jeff Bartnett's Avatar
Default Key does not come out unless brake pedal applied
So going to repost this since it's still an issue. 2003 H2. So the wires broke at the selonoid at the bottom of shifter causing key to be stuck. I replaced the connect and all wires were correctly matched/ connected. Selonoid on the shifter was replaced. Brake pedal sensor replaced and shift position sensors on tranny replaced. Still issues. If I go to turn off engine and remove key, key turns to engine off position but will not turn to the last position where u can remove key unless I put key in the run position and apply brake pedal and turn key to full off and then it removes. I'm baffled.
Old 08-17-2016, 01:40 PM
HUMTECH's Avatar
sounds like you have a wire crossed at the connector on shifter
Old 08-17-2016, 03:34 PM
Wish I did but they are connected correctly. Checked them three times. Also checked my solders job by testing voltage at the plug and that's all good.
Old 08-17-2016, 06:03 PM
HUMTECH's Avatar
Key does not come out unless brake pedal applied-h2ignlock.gif heres the ign lock schematic
Old 08-17-2016, 06:05 PM
HUMTECH's Avatar
Key does not come out unless brake pedal applied-h2shiftlock.gifheres the shift lock
Old 08-17-2016, 07:21 PM
citiboy's Avatar
juicebox123
05-19-2015 02:51 PM
4u33er
06-06-2012 09:41 AM
AMG55
04-15-2008 11:32 PM
HummerGuy
02-18-2007 10:17 PM
melvynray
12-06-2006 04:44 PM
Quick Reply: Key does not come out unless brake pedal applied
