Injectors clogged
Injectors clogged
I think I have the injectors clogged on my h2. I had the errors P0171 and P1074 come up a few days ago, but they cleared by themselves after I started the car again after a couple of hours. I've been noticing some loss of power at about 50mph, in low RPMS, I notice the car is loosing power but if I step on the gas, everything goes alright for some minutes...
Today I noticed a real loss of power, I was stepping on the gas and the car wasn't responding like it should, so I'm thinking it might be clogged injectors.
I was thinking of buying sea foam and pouring it on the gas tank, to see if it clears up a bit, and also change the fuel filter. My h2 is 2003, the fuel filter is not in the fuel pump right? I'm not sure about this, if it is in the fuel pump, then I'm not going to replace it...
Took out the air fillter which is almost new, and there was nothing blocking the MAF, it was clean..
About the fuel filter, the H2 fuel filter is outside the pump, I've located it.
I'm probably going to switch it, but I doubt that will solve my problem..
Where did you locate your fuel filter outside the pump/tank?
the photo isn't that good, but it's what I have.
The fuel filter is hidden over where the arrow points at. It's in there.
I just bought the sea foam today, should have it in 2 weeks... Let's hope this helps solve the problem the h2 has been having...
Thanks Cash. I've been up underneath my 05 H2 looking for a filter as it seemed crazy that it wouldn't have a fuel filter. I'll look again in the area you photo'd (thanks by the way!)
Called another H2 dealer south of Denver to ask the same question and the Service Writer told me that the only "filter" is that of the fuel pump sock, or screen that is attached to the fuel pump in the tank. 05 H2 did not have an "in-line" filter anywhere leading up to the Injector rail n the engine compartment.
For what it's worth, i've always had good success with the BG 44K fuel system, tank, inj and combustion chamber cleaner. Just dump a whole can of it into a full tank of gas. Comes in a black and gold can that runs around $20.
Thanks again for the pic.
My experience
Bg 44k does work well and is worth a try but I would use 2 cans in 1 tank of gas. If that does not do it than professional fuel injector service involves hooking up a machine that runs your engine during the cleaning process since they will remove your fuel pump fuse and that works very well as I purchased the snap on machine off ebay about 5 years ago..... I know....
Snap On Machine
I paid about $100 and there is one on ebay now item #180838941074
NAPA auto parts should sell the fluid that goes inside but remember you
have to remove the fuel pump fuse and best to disconnect the fuel line
at the manifold so no cleaner will flow backwards to the fuel pump or the tank.
