I bent my runningboards on accident today. :(
Old 08-27-2011, 07:51 PM
XxCC3xX's Avatar
Default I bent my runningboards on accident today. :(
I bent my stock runningboards or sidesteps whatever you want to call them today and they are bent forward. What do I need to do to fix them and fix them fast and cheap.
Old 08-27-2011, 07:52 PM
XxCC3xX's Avatar
Old 08-27-2011, 08:41 PM
Muddydawg75's Avatar
you can try to pull them backward.... but it's not going to be pretty.
I know people have tied them to a post and driven slowly in the direction they need adjustment.
Old 08-27-2011, 09:37 PM
XxCC3xX's Avatar
Smile
I'm probably going to take them off for awhile and fix them, I'll probably hammer them back somehow. I already tried to take them off but some of them are stuck and it's hard to get to them when there is a price of metal in the way.
And on top of this when I was lying down to look under the H2 my IPhone fell out of my pocket and the screen cracked. I'll see if Verizon will replace it.
Old 08-27-2011, 10:31 PM
Many people have just taken them off. You may be able to pick up a set very cheap.
Old 08-28-2011, 07:44 AM
Caraddict's Avatar
Man you are having a ruff time as of late...I'm sure if you remove the damaged one, heat up bent parts with a torch you will have no problem bending them back so they look almost perfect. Good luck!
Old 08-28-2011, 08:11 AM
XxCC3xX's Avatar
I have to keep them on because I have a lot of shorter people that can't get in without the Running Boards.
I'm probably just going to go down to a hardware store and buy all the tools I need to bend them back.
Thanks guys.
Old 08-28-2011, 08:14 AM
Mr. Fancy Pants's Avatar
I've had those day, I feel your pain. Hope you get them fixed.
Old 08-28-2011, 11:00 AM
drtom's Avatar
Banned
I have to keep them on because I have a lot of shorter people that can't get in without the RunningBoards.
i found mine too high to be usefull,had to step"up" to get out and step down,more work for my old legs. i made 4 inch lowering blocks,,,works great for me,AND kids
Old 08-28-2011, 04:30 PM
XxCC3xX's Avatar
Thumbs up
I got them to where the wheel doesn't rub them when I turn. I just took them off and took a hammer to them. On Tuesday I'll take them off and repaint them.
No_Fear_H3
17
10-08-2010 05:25 PM
Shale
12-28-2009 03:39 PM
HARDxCOR3
19
04-11-2008 03:05 PM
importkiller
16
02-22-2007 03:29 PM
hybridchaos
01-14-2007 01:09 PM
Quick Reply: I bent my runningboards on accident today. :(
