Hummer suddenly stopped
Old 05-14-2012, 02:00 PM
powerboat's Avatar
Default Hummer suddenly stopped
Hello today my Hummer h2 suddenly stopped in the middle of the freeway i had to be towed by a traktor, not so funny. wenn i got to the garage i tried to crank in but it would not start. i broke the power to the battery and left. came back one hour later and the car started and run for a weil and stopped again this has happend before last year. i live in Sweden so taking it to a workshop is not an option right now because thats gone be wery expensive. i need all the help i can get thanks.
Old 05-14-2012, 03:00 PM
2wheelmonster's Avatar
is there any check engine lights coming on?
Old 05-14-2012, 04:02 PM
powerboat's Avatar
Nope no check engine light
Old 05-14-2012, 05:03 PM
powerboat's Avatar
Is there more than one fuel pump on a h2? And where is the fuel filter located?
Old 05-14-2012, 09:41 PM
AKDropm's Avatar
Smile
Try swaping your camshaft position sensor. Had this happen to me a couple of years ago. There was no check engine light just died. Started up after it died a couple of time and i thought it was a fluke. Ended up being the Camshaft position sensor.
Old 05-15-2012, 06:30 AM
AKDropm's Avatar
Well there is only 3 reasons a car doesnt run. Air, Fuel, or Spark. You can check fuel with a pressure gauge. You can check air and make sure you filter isnt clogged. Most problems are Spark due to all of the electical components. pull a plug and have it hooked up and see if you ar getting spark. Then work your way backwards. Without a check engine light your only bet is to swap sensors that control spark. Crankshaft and camshaft position sensors are what distributorless ignitions use to determine when to spark. If this is faulty then you have no spark. For the $50 to change the sensors i would just try them first. Since you have no repair shop to bring it to.
Old 05-15-2012, 01:57 PM
H2CANEPADESIGN's Avatar
Agree with AKDropm, just have to go through the steps, check that your getting fuel (filter is on left hand side roughly under the driver seat along the frame rail) fuel pump is in the tank.
Old 05-16-2012, 06:24 AM
markushp's Avatar
I ran into similar mystical stoppings, on lights, on the highway etc. I replaced fuel pump, crank pos sensor etc etc.
It turned out to be water in the PCM connector, some of the pins had oxydation on them one of them being the fuel pump relay control. Took about 15 minutes to fix with a little rubbing alcohol.
Old 05-22-2012, 10:38 AM
powerboat's Avatar
I started the engine with a fuelpreassure gauge today and it shaked between 50 and almoust 10 psi
Old 05-24-2012, 03:07 PM
I can't find the specs on the Hummer but on a 6.0L chevy express 3500 van its 55-62 psi. no more and no less. Same engine.
Quick Reply: Hummer suddenly stopped
