help programing new keyless h2 remote
Old 11-21-2013, 10:12 AM
Hummin0814's Avatar
I don't know if this will work on the H2, but both key remote fobs for my 2007 H3 broke at the hole where the key ring goes through. I ordered two new ones off Ebay for $10 each.
Instead of paying the stealership to program, I popped open the new ones and removed everything - the rubber, the chip, and the battery. I opened my old ones and put the old rubber, old chip, and old battery into the new shell.
Much to my delight, they worked perfectly, and I avoided having to pay $25 to $50 each to have them "programmed". They pop open pretty easy - you can just use a penny on the bottom slot (below the ring hole) to pop them open.
Hope this helps.
Old 08-19-2014, 05:44 PM
ant69's Avatar
I had similar issues resetting mine the first couple tries. Try to just go through the steps in order but dont worry about waiting to turn the key or holding the button for the five/ten second counts. Just do the steps in order at your pace and watch for the lights. I had similar issues when looking up little dances lke this for programming and resetting things in my Vette.
Old 05-03-2018, 10:04 PM
clsimmon's Avatar
Originally Posted by fyr145
"not before you let go of the unlock button, then the vehicle has not entered programming mode"
For some reason on this particular '03 that I have, as soon as I turn the ignition off the 2nd time, the door locks cycle on/off before I release the unlock button, and I'm not able to enter programming mode. Have others seen this? It seems strange as I've programmed other trucks without issue. Perhaps I need to reset the entire system somehow first?
ctdrl-1
08-20-2015 03:20 PM
Diablito
07-10-2010 11:07 PM
bham57
07-06-2009 01:20 PM
H2Germany
09-08-2007 11:09 AM
whitestick
05-23-2007 03:24 AM
Quick Reply: help programing new keyless h2 remote
