HELP! H2 rattle
HELP! H2 rattle
hi im new to hummer and this forum. i have bought a H2 with 70k miles about 5 months ago and over the last couple weeks it has developed a rattle that sound like metal to metal for the first minute of start up! sound as if its coming from pass side close to front door area. i have been under it and checked everything and nothing is loose, i changed the oil and used 10w40 and its still there. anyone else have or had this problem? kinda thinking it my be the mains rattling, thanks for any and all info. brian
Thanks Doberman7892 i would like to speak with you over the phone. i will call you if you will send me your number. brian.maples@ymail.com
k ichanged the oil and filter again, ac filter and 530 oil. no difference at all. with a broken manifold should i hear this at all times? the only time i hear this is first thing in the morning on the first start up and it may last 30 sec it may last 1min, its never the same. it sounds like a rod is knocking when it does this
the broken bolt...or bolts...allows exhaust gas to escape from under the manifold. As the engine heats up the manifold expands and seals off the leak so you no longer hear it. This is a common problem with H2s and many times more than 1 bolt will break. There are stronger bolts available and it would be a good idea to replace all of them to prevent it happening again.
BTW... putting in a heavier oil might hide an engine noise for a while, but it doesn't solve the problem. Whatever is making the noise is still there and in time will probably only get worse....just my 2c
Rattle
The dealer showed me the mounts he replaced. He told me they were liquid filled and one had leaded down and would rattle against the exhaust manifold. Since it has been replaced, the noise has gone away. I also had to reseal the two corner roof marker lights. They were leaking and running out the grab handles by the front windshield. Hope this helps.
