Help fixing small leak
Old 11-13-2011, 07:04 PM
ukpaul's Avatar
Default Help fixing small leak
Found this today when I lifted hood. I think it's attached to the water pump. You can see where the water has been seeping out. I was wondering if that is a threaded tube that screws into water pump and someone has put a load of that red gunge on the thread but it's given way. Any input would be much appreciated. Thanks
Attached Thumbnails Help fixing small leak-img_0458.jpg   Help fixing small leak-img_0459.jpg
Old 11-16-2011, 05:04 PM
Muddydawg75's Avatar
kinda looks like the thermostat housing... hard to tell from that angle though...
Old 11-16-2011, 05:59 PM
ukpaul's Avatar
Thanks for the reply. It doesn't seem like the thermostat housings that i'm used to.
This looks like a tube with a rubber hose going to it. Looks like it goes into water pump.
Old 11-17-2011, 02:12 PM
REBREATHER's Avatar
Hi there the tube you see is pressed there as it where you need to change the water pump.
Old 11-17-2011, 03:22 PM
ukpaul's Avatar
I was wondering if it was threaded in there. That sucks. So i need a water pump ??
Old 11-18-2011, 12:17 PM
REBREATHER's Avatar
No it is not threaded .. it is pressed
Old 11-18-2011, 02:33 PM
ukpaul's Avatar
Thanks for reply. Does that mean new water pump then ??
Old 11-19-2011, 12:23 AM
REBREATHER's Avatar
Yes you need to replace this pump. This pump is not expensive . I think i give about 150 dollar here in sweden .
Old 11-19-2011, 07:26 AM
ukpaul's Avatar
Ok. Thanks
taxifornia
07-02-2012 11:55 AM
gnochi71
04-01-2012 04:57 PM
jacaron
06-02-2009 05:40 PM
meero
02-21-2009 07:03 PM
aycedad
03-19-2006 09:43 PM
Quick Reply: Help fixing small leak
