Help
Help
hi i have a 2005 h2 but im having problems with my AIR suspension sometimes it goes up and stays up for months but then it goes down and wont come back up it would stay down for a long time then all the sudden it goes up on its own its down now can anybody help?
probably a bad level sensor in the rear try disconnecting the plug and clean the connections and put some electrical greese on it might solve the problem if not replace the level sensors cost 100 a piece takes about 10 mins you can do it yourself with a socket set
I was having a similar problem,thank you for that sir.
