HELP! '08 Tires
Old 05-24-2015, 01:55 AM
bsim's Avatar
Angry HELP! '08 Tires
Time for some new shoes for the Ultra Marine.
However, Goodyear RS-As were discontinued some time back. Seems no 305/60-20s are available any longer. WTF?
But I don't need LT off-road "trucK tires like the M/T or mudders that are prevalent in the 35x12.5-20s. 90/10 on/off road - what's a streeter to do?
Old 05-24-2015, 07:47 AM
Search for metric size 325/60R20 LT
Old 05-24-2015, 10:36 AM
Synthetickiller's Avatar
Keep in mind,these will not fit, at least within specs.
Every 325/60R20 tire I've seen requires at least a 9" wide rim. The stock hummer wheels are 8.5". Around here, a lot of installers will not put them on as the wheel is not within spec.
I'm not saying you can't get it done, but for the time being, I just swapped out to 17s & put on 35s. The vehicle rides the same, height wise, but rides smoother due to more sidewall. The bonus of moving down to 17s is tires are relatively cheaper. I could get 17s + 35s for the price of just tires for 20s. It's something to consider. I don't understand why GM didn't make a 20x9 vs 20x8.5. If I ever go back to 20s, I'm buying a 20x9 wheel, just do to this tomfoolery.
The only 315/60R20 I've seen is the Toyo MT which is not a street tire, will ride horribly & wear quickly.
There is a 295/65R20. Again, a Toyo (Open Country AT 2). I owned a 35" pair & weren't happy at all with anything. I sold the wheels/tires to a neighbor who just needed something for a work truck. These don't do well for street drivers or even offroaders. Just my experience with the tires. Nitto also makes one, but's another MT.
305/55R20 will put you at about 33.2", so that's 1.2" lower than before. It's an option, but most people wouldn't want to lower their ride heights & effectively change the speedo readout (it's not major, but 65mph is just under 63, for instance).
Also, take into account that if you put on an AT like the BFGs that came stock or the new KO2s, the weight will affect acceleration.
Maybe others can speak up about putting 325/60R20s on an 8.5" wide wheel. I wasn't willing to take the chance of it blowing out or having insurance issues if I was involved in a wreck.
Old 05-30-2015, 10:31 AM
Ever pick out tires?
Old 06-03-2015, 01:03 PM
H2CANEPADESIGN's Avatar
35/12.50r20 nitto terra grappler g2. good tire, decent price, not noisy.
Old 06-03-2015, 05:06 PM
mattdillon's Avatar
Just go to tirerack.com & put your info in & i'm pretty sure they have just about Any tire you want! jmo! GL!
Caraddict
57
03-28-2018 12:42 PM
Pelvicthrust
09-28-2012 10:52 PM
smokemaster60
09-07-2010 04:56 PM
05roush0090
10-30-2009 06:51 PM
importkiller
29
01-15-2008 02:51 AM
Quick Reply: HELP! '08 Tires
