Headlights-aftermarket options
#21
The DRL strips on the top and bottom of each headlight is a nice touch also. I wired them into the power for my LED DRL's so those little strips are on all the time with the DRL's.
#22
LED Headlights
Thanks for all your input on this subject! I ordered a set of the headlights today. Excited to receive them! Did you have to make the hole in the rear of the housing a lot larger? Just wondering how much I am going to have to remove. Thanks again!!!
#23
Yes the hole has to be widened a significant amount. I went slow to try and make it as close as I could but it took so much time. Honestly just get a good rasp bit and start chewing the plastic away. Check the fit from time to time. You will have to chew out a small circle toward the bottom of each bucket to give the wiring more room.
#24
LED Headlights
Thanks again! I don't suppose you took any pictures of the headlight replacement including the housing mods? I just thought I would ask before I start cutting. No big deal if not! Thanks again for all of your assistance on helping us all update our H2!
#30
Removed the brush guard, the grill, and the headlight buckets tonight. Plan to modify the buckets tomorrow, plasti-dip the grill, and splice into the drl's for the headlights. I really appreciate all the help you provided on this! Much thanks!!!
