H2 Voltage Gauge Problem
I have 2005 H2 the voltage gauge stays at the zero point on startup and reports no voltage. I have validate the output is 14V from the Alternator and the battery is charging. Does it use some kind of sending unit to report the voltage that could be out or is this a cluster problem? Any help is much appreciated.
Had the same issue with the speedo.
The steppers are really cheaply made its amazing they actually work at all.
Get a kit, follow the destruction's, takes about an hour
logicbyondreason
10-20-2011 09:30 PM
General
01-13-2008 12:43 AM
