H2 Voltage Gauge Problem
Old 02-04-2016, 06:15 PM
Frosa's Avatar
Default H2 Voltage Gauge Problem
I have 2005 H2 the voltage gauge stays at the zero point on startup and reports no voltage. I have validate the output is 14V from the Alternator and the battery is charging. Does it use some kind of sending unit to report the voltage that could be out or is this a cluster problem? Any help is much appreciated.
Old 02-04-2016, 07:20 PM
flyday58's Avatar
Lots of peeps been changing the stepper motors in the cluster. Dirt cheap on fleabay.
Old 02-07-2016, 05:37 PM
oceanbrave's Avatar
Second that
Had the same issue with the speedo.
The steppers are really cheaply made its amazing they actually work at all.
Get a kit, follow the destruction's, takes about an hour
Old 02-08-2016, 09:42 AM
Frosa's Avatar
Thank you will order up a set and replace them.
Old 02-10-2016, 09:45 PM
Frosa's Avatar
That was the trick!! Thank you for all the help I replace all of them with new stepper motors and work awesome.
Old 02-10-2016, 09:57 PM
flyday58's Avatar
Glad to hear it, excellent work!
Old 02-11-2016, 04:11 AM
oceanbrave's Avatar
Yes indeed very well done and quick too!
pablo77
06-17-2013 01:15 AM
logicbyondreason
10-20-2011 09:30 PM
palmxjjsi
05-18-2011 09:11 AM
SC_Hummer_Guy
11-23-2010 06:57 PM
General
01-13-2008 12:43 AM
Quick Reply: H2 Voltage Gauge Problem
