H2 Heat only works when set at 90 degrees!
The module is located under the passenger side glove box. You must first remove the plastic panel to gain access to the module. Then it's just a matter of disconnecting the plug and then unscrewing the module itself. Keep in mind the orientation of the unit when you reinstall the new unit. I think it may only fit the correct way. Let me know if you have any further questions. Thanks.
Ben
victoriag26
11-16-2014 12:41 PM
HumV
11-06-2014 11:31 AM
Husa4342
03-27-2011 09:06 AM
jeffwhiteis
12-16-2010 01:41 PM
hearseman
08-05-2010 09:26 PM
