h2 differential bushings
My upper and lower oem rubber bushings are deteriorating on my differential crossmember. Apparently the only available fix is getting a whole new crossmember....seems a little ridiculous for two pieces of rubber. Has anyone done a diy fix? I'm thinking of modifying a poly bushing or cutting a body mount puck to size....does anyone know the exact diameter or height?
I just saw a similar post on a different forum. Canadian hummer club. There is a guy named roy. That has just started making the bushings and sells them. It is one of the top threads in the h2 section. If you want to see what it involves. Sorry Don't know how to post links.
PA Ridgerunner
10-25-2010 11:11 AM
Jogi
08-19-2009 09:40 AM
