A good oil-free air filter...?
My mechanic recommended me to use NOT an air filter that uses oil for increasing the capacity to retain impurities. This is because in the long run, a small amount of oil could be sucked into the engine. If you want then change the original air filter with a better performance, which filter can improve the original but without the oil?
Thanks and greetings from Italy...
It's not oil being sucked into the motor thats a problem; its the fact that the oil can dirty up your maf (not a huge deal; just clean it..) but also when you offroad, every particle of dust is gonna get sucked to that filter all day long.
Go with a spectre or k&n oil-free filter. They are both good.
K & N filters are without oil...? I knew otherwise. For example, the model 63-3037 or 77-3037KP really are oil free?
And what would these filters "Spectre"?
Thanks again
Luigi
http://www.google.com/search?q=spect...W_enUS366US366
yes there are some oil-free k&n's you can buy tho.
I know that dr tom got like a 2mpg increase by JUST switching the filter out to a good one, on his stock airbox. Adding an airdoc into the equation, which would eliminate the resonator you speak of, would yield even more mileage.
hummer07
11-18-2008 10:46 AM
efrainl956
06-20-2006 12:24 AM
