Fuses
Old 06-07-2008, 05:42 PM
solarflare's Avatar
Default Fuses
Is there a fuse block, when you open the driver's door, on the side of the dash? If so, how do you access it? I assume you pull on the plastic piece....but I don't want to pull it to hard....
Old 06-07-2008, 06:40 PM
Muddydawg75's Avatar
Default RE: Fuses
Yeah it is held in with 4 clips... one at the bottom where the picture of the fuse is... 1 in the upper middle and two at the top by the hole
Old 06-07-2008, 06:41 PM
Default RE: Fuses
Pull at the bottom and if you look you can see the one clip. Then work your finger or a trim tool in there and pop the top ones. It fits very snug.
Old 06-07-2008, 07:37 PM
solarflare's Avatar
Default RE: Fuses
thanx Stan.....snug isn't the word for it....
solarflare's Avatar
Default RE: Fuses
more like impossible!
Old 06-08-2008, 08:43 AM
Default RE: Fuses
Those clips are pretty strong. As long as you pry out and not at an angle you shouldn't break them.
Old 06-08-2008, 08:44 AM
Default RE: Fuses
BTW... your spare fuses and fuse puller are mounted on the panel inside.
Old 10-04-2011, 11:19 AM
beltwaybob's Avatar
There is a big fuse box under the hood by the battery. Is there a secret to getting the lid off? I have tried and failed.
Bob
Keithmo
06-25-2014 07:44 AM
wrbrackett
09-24-2008 01:44 AM
SafariHummerH2
06-08-2008 07:55 PM
arichie
10-22-2007 05:16 AM
Quick Reply: Fuses
