Fuel door - Hummer Forums - Enthusiast Forum for Hummer Owners
Reply
Thread Tools Search this Thread
Old 10-19-2011, 05:01 PM
Default Fuel door
Hi all, just became a proud owner of my first H2....A 2006 in nearly mint condition. One of the items that need replacing is the factory installed chrome gas door. The chrome is flaking and the hinge has started to let the door hang to one side. Bought a locking door on E-Bay (Bully) and followed the instructions, however the product would not fit into the plastic shroud. The assembly on there is 7 1/2" while the new assembly is 8". I sent it back and order another one, same size! Am I missing something here? Has anybody had to replace the factory door?..Thanks in advance, and I look forward to enjoying my new ride and discussion in the forum!
Old 03-23-2012, 04:06 PM
what did you end up doing? same problem here
Old 03-23-2012, 04:19 PM
LoJac963's Avatar
I'm actually looking to replace my stock chrome one as well since I can't stand the chrome. Do you just remove the allen bolts and the entire fuel door comes off?
I kinda figured all the doors would just work but I guess not-thanks for letting us know!
Old 03-23-2012, 11:35 PM
fyr145's Avatar
Default Different fuel doors !
Quote:
When I got my H2, I didnt like the fact that my fuel door wasnt lockable. One of the first items that I purchased was the chrome fuel door. I did some research and found Defenderwerx made them for the H2. However, I went to a distributer at GStyle4u and they ended up sending me the wrong one even after I told them I had on '07 H2. WHen the first one arrived, I was going through the very same issues you were and almost trashed my outer fuel ring that sits between the door and the body. I called them back and they had no idea. So this time I called the manufacturer directly (Defenderwerx) and they informed me that yes there are TWO different kinds of fuel doors. I gave them the part number for that was sent to me by Gstyle4u and the guy at defenderwerx said it was the other one. After my discussions with them, the guys at Defenderwerx were kind enough to not charge me shipping because of GStyle4u's error in not checking this for thier customer.
In the end, I had to ship the wrong part back to Defenderwerx and once they got it, they sent me the correct one! Now I have the correct locking fuel door!! This was a good lesson in being careful when dealing with the middle man!!! All I got from them was the run around and was told they had to "backorder" the part. Yeah, right. As a result of this occurance, I will not buy anything from Gstyle4u.com ever, nor would I recommend them to any fellow Hummer owners.
Ok, if you are going to get one from Defenderwerx, the one with the allen screws which goes on the '06 and newer H2's is # H2PPL08030. The other one, which sounds like the one you got goes to '05 and earlier model H2's is H2PPC08030.
Sorry you had to go through the same problems as I did, maybe this post will help some other H2 owner sometime.
Old 03-23-2012, 11:37 PM
fyr145's Avatar
Default Fuel door.....
Lojack,
As long as you have the correct model, then yes, the 6 small allen screws is all you need to do, be careful not to crank on them too tight, they are small and will strip easily.
Hope this helps!
Old 03-24-2012, 07:26 AM
Thanks for the info..I ended up buying a new plastic bezel, drilling out holes for the allen screws, then buying slightly longer stainless allen screws to get mine to work. Great to know there are different parts and I wasnt going daffy!
Old 03-24-2012, 04:40 PM
LoJac963's Avatar
Quote:
Originally Posted by fyr145 View Post
Lojack,
Hope this helps!
awesome, thanks. I might end up picking up the GM black locking door but they're a little pricey!
Old 03-24-2012, 07:00 PM
fyr145's Avatar
Smile Fuel door.....
I agree, they are pricey. I also noticed that when I installed the new chrome locking fuel door that the tumblers were a bit sticky, so I headed over to my local hardware store and picked up a small tube of dry graphite and it solved that small issue right up! Now the door works just fine.
Old 03-25-2012, 07:38 PM
LoJac963's Avatar
great advice, I have a tube of that stuff around here somewhere
Old 06-11-2015, 08:42 PM
Thanks... I know this thread is old but, very helpful in getting the correct door
Reply
Thread Thread Starter Forum Replies Last Post
H3 Fuel Rail W/Fuel Injectors yardcrew PRIVATE For Sale / Trade Classifieds 0 08-12-2014 08:06 PM
WTB: '06 H3 Fuel Pocket/fuel bucket mismatch Private 'Wanted' Classifieds 1 09-01-2013 10:42 AM
H3 Chrome Fuel Door with "HUMMER" engraved + Fuel Tank Bezel. Davidh3 PRIVATE For Sale / Trade Classifieds 0 11-10-2011 04:51 PM
Adding GM chrome fuel door to base model CarlosC Hummer H3 19 12-01-2009 08:35 PM
Stallion Customs Raffle "FUEL DOOR" stallioncustoms Off Topic 11 02-01-2006 05:06 PM
Tags
bully, chrome, door, flaking, fuel, gas, h2, hummer, install, installation, locking, long, remove, replace, replaceing, screws
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
