Can I do 22
Old 05-07-2011, 12:28 AM
quicksilverz1's Avatar
Default Can I do 22
I want to add XD rock star rims to my truck and the 20s look small Can I do 22 stores keep telling me that 20s where as high as I could go without a lift is that true? I think I have read a few times that you can do 22 with no problem thats what I want. I want them to be wating for me when I get back from afghanistan I have less than a month and a half before I get home.
Old 05-07-2011, 09:42 AM
Marine1's Avatar
Recommend you use the search to answer most of your questions but here is a link to a good website that will set you up right.
Tire Rack - Your performance experts for tires and wheels
Old 05-07-2011, 10:04 AM
when you do them sights it tells you 20s are max I want 22 and I have seen 22s on alot of hummers I dont think they all got lifts so I am wanting to know it might not be recomended but yes you can or no you cant.
Old 05-07-2011, 10:19 AM
Marine1's Avatar
Yes but you need to use the site so it will teach what dimensions youll need to match up your tire size so you wont need a lift.
Old 05-07-2011, 10:27 AM
Cashville's Avatar
You can do it without any lifts, there is no problem.
Old 05-07-2011, 11:16 AM
Thanks thats what I thought but did not want to drop $3000 on rims without knowing.
Also does any one have suggestions on the best places to go.
Old 05-07-2011, 06:21 PM
colbymh's Avatar
Id stick with 20's. 22's look to weenie IMO and makes it look like it might as well be two wheel drive.
Old 05-08-2011, 05:18 AM
I have seen alot of H2 with 22" on them and think they look pretty good. But I also want to be able to go off road when you guys put together a Off road rally.
Old 05-09-2011, 12:08 PM
Crtlv's Avatar
all of my hummer limos run 22s.No problems at all and most of my hummers weigh in at over 14k pounds.
Im running 325/50/22 nitto terra grapplers and im getting 10k miles on each set before i see serious wear.And our limos arent Lifted at all.Just make sure you go with a good wheel and check the load rating some of the cheaper wheels are lower rated and can crack.Also i run my psi at 55 and i havent had a bent or cracked rim in over a year.
I am running davinci wheels on all of them and have been pleased with the look.
Old 05-09-2011, 09:50 PM
Should I be worried If I towe my boat its weights about 8000 pounds if not more fully loaded. I could get high impact tires like I had on my avalanch will that help.
Quick Reply: Can I do 22
