Broken rear exhaust bolts on both sides
Old 08-11-2014, 10:37 PM
09 Black H2's Avatar
Default Broken rear exhaust bolts on both sides
Is pulling the heads and removing broken studs the best and safest way.
Old 08-11-2014, 11:01 PM
Signal25's Avatar
You may be able to rockstar drill them.
If you are good.
My thread is a few posts down.
Thats what I am doing.
My buddy: " If you are going to pull the heads, may as well do a cam. If you are going to do a cam, may as well do an intake. And with all that, a tune. The car heads are lower CR so more Hp."
$4500 later. :-(
Old 08-12-2014, 01:46 AM
LoJac963's Avatar
There are a lot of threads about broken mani studs on the various forums. The vast majority, basically everyone, does not remove the heads. Would it be easier? Most definitely but also a lot of unnecessary work as well.
Heads, cam, intake, while all that would be fun to do I don't think the benefits in such a vehicle are worth the time and money IMO. You still have a tranny that is in the wrong vehicle I think. Even with more horsepower you're still running through the stock gearing which honestly would play a more vital role in MPG. In my 06 GTO, heads, cam, intake mani-most definitely!
Many people have regeared and been very happy with the results. Although I' think this thread is going off on a tangent lol.
Old 08-12-2014, 06:19 AM
citiboy's Avatar
I didn't need to remove the head when i did mine. The bolt broke with the stud sticking out enough for the vise grip to grab on. Installed an ARP 434-1301 stud kit and never had a problem.
Old 08-12-2014, 11:07 AM
Mine are all broken even with head.
Old 08-12-2014, 01:30 PM
ak47dennis's Avatar
Did you remove the manifolds yet to verify that?
Old 08-12-2014, 06:44 PM
Measured them.
Old 08-14-2014, 08:30 PM
Taking it Midas tomorrow to see if they can get them out if not next step, remove heads.
Old 08-14-2014, 09:07 PM
ak47dennis's Avatar
I would rather take it to a smaller garage that's known to do good work. Removing the heads won't be needed once the manifold is out off and the way.
Seems like your anxious to remove a head?
Old 08-14-2014, 09:09 PM
Signal25's Avatar
If you are close to the Panhandle of FL, we can pull your heads in a day.
They will be at the machine shop for 2-3 days. Be about $200ish and that's clean, deck, valve job.
Then a day to put back together.
Quick Reply: Broken rear exhaust bolts on both sides
