bds lift
bds lift
The BDS lift came in only a 6 and 12 inch option right? I believe my sut I just picked up has the 6" on it but 37x12.5 look really small. What is a good size to run for a truck that is driven on pavement daily? Also what's the max tire size you can run with that lift? Thanks Chris
That look really good! What kind of tires are they and what width? Also what's the back spacing on your wheels? And lastly does your rig see more off road then on road? My biggest issue is half the year my truck will be my daily driver (fall and winter). Worried about gearing also
what I do is have a set of wrangler mtrs on 17 inch for off road use. And when your mostly civilized use on pavement a set of 20 inch wheels with goodyear wrangler sra or if you want bigger maybe nitto terra grapplers. They dont last as long but ride is decent on highway.
if you want bigger do procomp TA
it will be great for off road. tread wont last well on road, probably would not do well in snow or bad rain and will wear you front end faster. however there are thicker tie rod ends and you can always change control arms etc. just know that down the road you have to do more maintainence
rockstarbass1
01-02-2015 09:52 PM
Caraddict
07-03-2014 01:11 PM
Brianb
08-20-2010 09:09 AM
stallioncustoms
01-14-2006 04:42 PM
