Aftermarket replacement Side Mirrors
Still trying to resolve mirror issue i.e. power-fold not working, pan-tilt mechanism gears stripped etc.
What about CARiD are these any good? (they seem expensive)
Or is there a good alternative?
Also would anyone know the part numbers for a 2005 model year H2 or where to find them?
Many thanks!
Many thanks!
ReplaceŽ - Hummer H2 2005 Side Mirror
However one sad thing is that many US sources don't ship to the UK which is frustrating but in some ways understandable.
Did you try the link for CARiD? After conversations with them a pair work out to cost $778.43 Hence my questions about them.
Share your sentiments mattdillon, I definitely don't want to spent the money, but spare parts are hard to come by here in the UK.
I can assure you that if I could have found away to repair the gear assemblies I would have. In fact I have dismantled one set right down to motor shafts and did manage to get it kind-of working by gluing back together the shattered main gear and turning it round to a section where the teeth hadn't stripped. It works providing you don't nudge the mirror too far. Short of redesigning or re-manufacturing the tiny high-precision composite nylon gear-rods etc once these are broken that is it. Incidentally its beyond 3D printing capabilities. Now if someone can supply the main gear and pinions then a repair would be possible ... anyone out there?
As for the power-fold motors typically these get water logged and rot in their mounts, very common on earlier H2's (see Hummer Forums by Elcova - View Single Post - Driver Side Mirror Not Folding In) Whilst it may be possible to restore these and put in the drain holes, it involves dismantling the door to get at the mounting bolts and there is no guarantee of success.
So my conclusion was to look for either spares, used or complete new side-mirrors. I've trawled the web for spares and found no sources as of yet. There are new and used ones on ebay but many people wont ship to the UK, used ones are risky and likely to be just as bad. So I'm stuck waiting for something to turn-up. A pair of mirrors from a write-off would be good.
Northsider10
09-27-2012 08:03 AM
jvorpahl
04-20-2011 10:54 AM
diamondh2
08-02-2007 01:04 AM
