Aftermarket license plate installed in tailgate
Old 12-23-2010, 03:19 AM
colbymh's Avatar
Default Aftermarket license plate installed in tailgate
So I have a 2007 and hated the tire carrier. Ofcourse after doing so I was caught a bit off guard that there wasnt a light setup for the license plate where the older models do.
I called around and oem setup was just under $500 and that included the black plastic insert thats already there. The oem one just comes with lights and wiring.
My setup... Putco chrome license frame ( very good looking part ) with a 12" piece of white flex neon led's. It's so thin that you cant even see it under the lip (eyebrow) of the frame.
Popped the inside liner off, drilled a small holes for wires and then routed wiring next to oem to the running lights and tapped in there.
The led lights glow over th plate and make it really look clean and custom. Total price. $160
Old 12-23-2010, 07:56 AM
cdwaterman88's Avatar
sounds kind of cool! lets see it!
Old 12-23-2010, 11:03 AM
mgurgone's Avatar
Post a picture... Sounds great
Old 12-23-2010, 12:04 PM
colbymh's Avatar
Old 12-23-2010, 12:10 PM
colbymh's Avatar
If you zoom in and look under the eyebrow lip you will see the flex neon led strip. Excuse the quality as they were taken at night w Iphone. The ones with lights on might have a shining effect or glare because of pic, but it looks awesome at night. It just illuminates the plate better and all the way across given its and led the length of the plate. Not a dull brown light look with the standard lighting.
Old 12-23-2010, 12:11 PM
colbymh's Avatar
Old 12-23-2010, 01:13 PM
calif phil's Avatar
Very Nice
Old 12-23-2010, 01:41 PM
colbymh's Avatar
Thank you. The pics lit really dont do it justice. Its clean and classy looking. Not like kid neon lights for low riders. lol
Old 01-09-2011, 11:55 PM
MARKCORE's Avatar
Looks great! I'm going to do the same thing. Took my spare off and have been debating on what to do. Any other tips before I start? ...and you just tapped into the old wires that the spare mount plugged into correct?
Thanks!
Old 01-10-2011, 06:42 PM
colbymh's Avatar
Thank you..I have some install photos if that would help you out? I have a hi-def video also.
I went with a cleaner oem style install and ran the wires along the wire harness and up to the three middle running lights. The other way wouldn't have worked since the gate has to come open (raise up). Anyone else wouldn't even know additional wiring had been used.
Quick Reply: Aftermarket license plate installed in tailgate
