Adding extra lights to the approach lights
Okay I have mounted LED lights off of my rack that i control with a toggle switch, they are my "crowd control" lights. What i want to do is tie it in where when every i hit unlock on my fob the side lights come on as well. the approach lights are DRL and reverse lights on at once. Does anyone know if this is a relay some where that i can tie into or any other ideas. Thanks.
here are the lights at night
looks pretty sweet i just bought my h2 6 weeks ago and i have to fix the minor mechanical issues before i can get the truck chromed up and dubbed and skinned, love your brush guard winch set up. nice truck you got there
You are going to need an aftermarket keyless entry system for this to work. Everything on that truck is controlled through the data bus. If it was 2002 or older, you could simply cut into the second channel that unlocks all other doors besides drivers w/ a relay. Splice the other half of that second channel into the 1st. Then 1 button press unlocks all doors, second press is what ever you want.
swr930porsche
05-12-2010 09:06 AM
2007h3x
02-19-2010 08:45 PM
BabyTank
11-23-2008 08:33 PM
HUMMER DRIVER
09-22-2007 02:04 PM
