Abs problems help
Old 06-14-2011, 11:18 PM
palmxjjsi's Avatar
Banned
Default Abs problems help
Have a 2005 H2 with 108k, ABS light comes on and TC turns off when you start driving, when you turn it off and restart it, the light is gone, start driving and then its back, I replaced both front wheel speed/ABS sensors and its still doing it, the codes that are coming up are C0245 and C0110, I need to get this figured out if there is any insight someone might have feel free to give me your input!
Old 06-15-2011, 02:12 PM
Gleamor's Avatar
Well the C0245 code is the wheel speed sensor frequency, and likely means you need to take it to the dealer to reprogram. Most times its from aftermarket wheels of 22" or larger from what iv'e seen. Worst case scenario you have a bad
electronic brake control module.
Code C0110 is the abs pump.
Both of these beg the questions, what size wheels and tires do you have. And have you made any modifications that would significantly affect the ride height, breaks, steering, or did you monkey around using a tuner.
Most of the time its good practice to take it by the dealer to have sensors reprogrammed once mods like that are done
samijane
04-18-2014 07:58 AM
rtwash
12-13-2013 10:45 PM
palmxjjsi
08-15-2011 10:56 AM
jameshd
09-17-2010 09:38 AM
Northerner
08-06-2007 05:47 PM
Quick Reply: Abs problems help
