2007 Hummer H2 Gas Cap and Check Engine Problem.HELP?!
Old 08-29-2012, 10:48 PM
phunkyhalloween's Avatar
I had the same issue with my 2003 H2. I replaced 3 items on my truck, the gas tank canister that is under the truck attached to the frame. Also I replaced a sensor on the top of the motor can't remember what it was called, it was on the top of the manifold on the front, under the plastic cover. Last I replaced the sensor on the gas tank, located on the top of the tank. It was the most expensive part but replacing them three parts fixed the problem. Just to let you know, disconnecting the battery does not clear the computer, the code will stay in the computer for up to 500 miles or so. The total cost of parts was less than 200.00 and you can replace the parts yourself because labor will cost at least twice that. You can only get the parts from the dealer, most parts store don't carry those items.
Old 08-31-2012, 02:21 PM
madmajd's Avatar
Originally Posted by Ricard350
I had the same thing happened to me, u did the right thing first u changed your gas cap. So ur cap is now out of the equation.
Mostly your gas tank vent selenoid is toasted and is open all the time. That selenoid is there to help vent the tank during refueling if i remember.
U have that warning displayed and a check engine because ur truck failed the gas tank pressure test and it gives u a vapor leak check engine code. The truck ask to tightnen the fuel cap just in case if it wasent.
At my local GM dealer when I explained the sympthom and told them i replaced my gas cap he knew that if was probably the selenoid.
He used his OBDII TECH 2 scan, and initiated a special test that cycle the selenoid on and off and test the seal and it failed immidiately.
So the selenoid is directly installed on the frame as u can see
N2 VAPOR CANISTER & RELATED PARTS (LQ4/6.0U);. Fits: Hummer H2 | Nalley Buick GMC Brunswick
item number 5.
So it costed my 45$cnd and if took .2hours of time for a final price of around 85$.
He ran the test after and it was a pass. and no more Tightnen fuel cap warning.
I just dont know why ur dealer could not think of that.....
Srry of my bad french canadian learned on the fly written english.
keep us informed
David
Thanks alot for all the info! I will definitely get that replaced, do you know if its easy to do at home by myself?
Old 08-31-2012, 02:23 PM
madmajd's Avatar
Yeah if replacing the solenoid doesn't work, then I will get the parts you mentioned replaced. Thanks for all the info
Old 09-23-2012, 10:39 AM
madmajd's Avatar
Just want to update everyone, I bought a new gas tank vent selenoid and replaced it at home, and voila, no more gas cap problems, but the computer hasn't cleared the code even though i changed it 3 weeks ago and i think i did over 30 ignition cycles
Old 09-24-2012, 06:44 PM
Ricard350's Avatar
Glad to know that it fixed the issue, now your H2 computer dosent think u havent tightned enough ur gascap.
As for ur engine code, disconnect your battery for 5-10 min then reconnect, it will clear all codes, and ur radio clock too.
Its a small price to pay to get rid for that annoying CEL.
cheers!
Old 09-26-2012, 06:08 PM
madmajd's Avatar
cheers!
Thanks a lot for your help.
Old 01-01-2016, 11:10 AM
budynski's Avatar
Default tighten gas cap
Originally Posted by madmajd
Hello everyone
I am the proud owner of a 2007 Hummer H2, bought it about 2 years ago, and put about 9,000 KM on it over those two years (now at 97,000). A while back (can't remember exactly when) my car told me "tighten fuel cap", so I tightened it, and drove, and it told me that again while driving, then came the check engine light. Its been like that for a long time now, it would tell me "tighten fuel cap" almost every time while driving. I got the cap changed, and still the same thing. I took it to the dealer, and they said they scanned it and didn't find anything (when it was under warranty), and told me that's normal (?). And a couple of days ago, the dealer contacted me about a recall for my H2 regarding a defective catalytic converter. I asked them to check the fuel cap issue, but then I changed my mind, thinking that it could have been a problem relating to the Emissions control system (my friend had a Hyundai that gave the same fuel cap/check engine problem, and it turned out that there was a loose hose somewhere around the Emission control system). Anyways, while driving a couple of days after the catalytic converter repair, it told me again to check the gas cap. So, what do you guys think?
Also, I tried putting acetone once or twice in the gas tank to get better mileage, but it didn't work. Could that have contributed to the problem? I got the issue a long time after doing that, though. I disconnect the battery every now and then to reset the computer to clear the check engine light.
So does anyone know anything about this issue?
Any help is greatly appreciated because I'm pulling my hair out from this right now.
Thanks!
their is a black plastic pipe on top of gas tank you can see it at back wheel on drivers side reach in and feel the pipe between plastic pipe and gas tank their is about 3 inches on steel that rots and lets out pressure from tank that makes light come on tighten gas cap
Old 01-01-2016, 11:14 AM
budynski's Avatar
Default tighten gas cap i reached in and pipe was just laying thier so i toke a smaller pipe
caulked them and put a bee hive typ on top with exspand foam message is gone about tighten gas cap did this with out taking down gas tank
Old 06-20-2016, 06:33 AM
otakimaori's Avatar
great, thanks for the advice, I will try and cycle on off the solenoid with my ob11 as I am having the exact same fault and I have already replaced the fuel cap...
looks like I got my weekend planned out for me, cheers
Humanoid
Private 'Wanted' Classifieds
03-27-2021 02:23 AM
Dieseldrums
12-09-2014 10:14 PM
Compndr
08-18-2014 03:56 PM
LoJac963
04-17-2014 06:59 PM
Poweraidion
02-16-2014 11:26 AM
Quick Reply: 2007 Hummer H2 Gas Cap and Check Engine Problem.HELP?!
