2005 Hummer H2 Steering wheel control lights
Yes, can some post up what is needed to buy and maybe a short guide? I have lights out on both the HVAC controls on the dash and on my steering wheel. I seem to remember they went out as a group, and may have gone on/off a few times before going out permanently. Basically, the right side of my hvac controls (ie - Auto) are out, but the left side is fine. I'm not sure if I just need to replace the LEDs or something else.
I have an aftermarket stereo, so that's not an issue.
This is a link for the seller, the LEDS are not the correct ones. All depends what color you want but they should be diffused lenses.
http://www.ebay.com/itm/12-Volt-3mm-...item2c937a42e0
if you are still looking for them (the whole assembly) I got mine on Amazon.
you need the following ones for a whole set.
dorman 901-120
dorman 901-121
dorman 901-122
dorman 901-123
Just search them as is and you'll find them (Prime too id you have it)
I have an extra P/N 901-121 if you'd be interested.
Replacing these requires patients because the wires are so short. needle nose pliers and a helper makes it easier.
dorman 901-120
dorman 901-121
dorman 901-122
dorman 901-123
dorman 901-120
dorman 901-121
dorman 901-122
dorman 901-123
dorman 901-120
dorman 901-121
dorman 901-122
dorman 901-123
Yup you just pry out the old ones unplug them plug the new ones in and push it back into the steering wheel. Like I said before the wires are short so it can be a little tricky. I got the full set so they would all match in light color.
I think I got them all for about $65 bucks shipped and in 2days (thanks to Amazon Prime)
It came out really well I think.
I still plan to try swapping bulbs/button assemblies just in case they are wrong, but I haven't got around to it yet. FWIW, the only ones that really bother me are the windshield defogger and rear window defroster. I don't know of an easy way to swap those like you can with the steering wheel buttons.
Agreed. That's why I follow threads like this when they come up hoping for new insight and why I had the dealer diagnose my issue. It's also why I haven't done anything - just not worth hundreds to get it fixed.
