2005 H2 Help Issues
Old 09-16-2012, 03:08 PM
ffks's Avatar
Default 2005 H2 Help Issues
I have a H2T, great truck with almost 100,000 miles & not a scratch on it!!
Three (3) recent issues if anyone can help:
1. Passenger side A/C blows HOT air regardless of turning the passenger climate contol temp ****. Driver side blows COLD air?
2. Driver seat folds up or inward when you stop and turn the key off! Everytime you start the truck you must reajust the seat position, thats a real pain the ***!
3. This one I may have figuired out is the Air Level Sensor, sometimes as soon a you turn the key off the rear air bags lower, sometime you could leave it parked for a month and it doesn't lower!!??
I love my truck, wish I could order a new one!!
Old 09-16-2012, 03:29 PM
bflorin's Avatar
1) theres a blend control motor that adjusts between hot/cold, probably took a dump.
2) try your second set of keys thats most likely coded for a different driver. Pretty sure you can set a seat position for exiting the vehicle. Should be in the owners manual.
3) couldn't tell you on the air shocks...I dont have'em.
Old 09-16-2012, 03:35 PM
ffks's Avatar
Thank you for the help...
Old 09-16-2012, 06:23 PM
bflorin's Avatar
#11 I believe
A scan tool should be able to diagnose a non-responsive actuator.
ticknlo
09-22-2013 02:54 PM
HummerGerhardt
09-01-2013 10:49 AM
Kreke
10-10-2008 06:07 PM
opulido
16
02-23-2007 10:50 PM
jm4490
12-19-2006 04:52 PM
Quick Reply: 2005 H2 Help Issues
