2003 H2 water leak
2003 H2 water leak
Hey guys, wondering if any of you have had trouble with a water leak. I am getting water from somewhere down into my heater blower motor assembly, They have checked my windshield, marker lights and all over and can not find where the water is coming from. When it rains my passenger side floor is wet as hell. Any ideas??? Its killing my blower motor
Sunroof. Drains get plugged, then water leaks down A-pillars and ultimately onto the floor.
You will most likely need to pull your carpet and disinfect it/spray otherwise it will mold like crazy. I'm sure its starting to stink already???
Could be the passenger door seal. I have had a couple cars in the past where either the door seal went bad, or the door was not lining up properly when closed and not creating the proper seal with the weather stripping.
Since you can't find anything from the usual H2 problems you may want to look at this
Best of luck!!!
Best of luck!!!
This was a big problem - esp in 03. Do you notice it at all in your vents or lights above the dash?
I had big problems with the seals under my roof lights front and rear. I made new and have no problem with water in the car today . And i live in sweden there they raining every day mostly .... try it and you have a dry hummer .
