2" bodylift
2" bodylift
I did the 2" bodylift a while back and today fabbed up some spacers for the rear bumper. I still have to put in the long piece across the back under the hatch but the corners were the priority. I attached some before and after pics...
Thanks....I used aluminum right angle pieces as mounts that went under the lip on the body. Then I used 1/8" aluminum, cut everything with a sawzall and bent the corners over a wood 4x4 in a vise. I used 3m tape to secure everything.
Funny thing is, I did a 2" lift but needed 3" wide aluminum to fill the gap. Spent $17 on Aluminum. Better than the $400 the shops wanted to charge me.
I'm in New Port Richey north of Tampa
I did my 2 inch BL today, very simple, toughest part was the placement of 4x4 blocks to lift the body off the frame..
Also used 2 inch spacers to fix the front bumper..
Now i just have to modify the rear, i plan on raising the bumper, i feel it gives a better, finished look..
BEFORE:
AFTER:
BEFORE:
AFTER:
As far as the rear, all you have to do is use 2x2 steel , is raise the bumper support, its only bolted on anyway, as to the part that is cut, that is only for clearence, no harm will come to the frame, btw, not even sure if it has to be cut, we will see..
Just the right way to do it, plus for those who off road, it will provide more clearence while coming off an obsticle. ..
Club Hummer Offroad
Yeah, like this? No thanks. Looks like cutting to me.
Also I remember you have to cut the bottom edge of the frame for the bumper to fit after.
It won't give you any more obstacle clearance as the frame underneath is the same except for the couple inches you hack off and lift attached to the bumper.
It does give a better look I agree, good luck.
im looking at doing a 1" body lift possibly to help out with steering my 44s...
anyway, curious if anyone can help with what i all need for quantities on the blocks and what size bolts i need to go with them. If i am going to attempt it, i want to have everything that i will need before i start the process.
thanks,
steve
thanks,
steve
well i found this for a 2" i guess i can just use it. of course i found it after i posted, after searching for almost an hour haha
Hummer H2 2" Body Lift - How to guide
Required Tools:
* socket wrench or impact wrench
* socket size 18 and 19
* torque wrench
* socket extension
* floor jack
* hacksaw or circular saw
(Get a day laborer or someone to do it for free)
Required parts:
* 12 Zone Offroad Bulk 2" Tall x 3" Wide Body Lift Blocks
* 12 M12-1.75 x 170mm DIN 931 Class 10.9 Plain Finish Hex Bolts
steve
Required Tools:
* torque wrench
* socket extension
* floor jack
Required parts:
steve
I'd love to see some pics during the process, especially surrounding the bumpers and if they just fit back on etc. I'd like to lift mine a little more (just have her levelled), but something about fabricating new brackets for bumpers etc that put me off, and not such a fan of the gap. Shame someone doesn't fab up and sell a proper kit, with a couple of variants, i.e. 1" or 2" kits...
