07 H2 Header mod benefits or not?
Looking for improved engine heat reduction and seen somewhere headers would help? Any recommendations? Would a Cold Air intake system help reduce heat also since it potentially pulls cooler air? I'm familiar with Cold air intakes as i have a Spectre on my 01 Suburban LT 4x4 5.3L.
I would also like some feedback from those that have done the mod and how it turned out if possible..MPG changes etc...
Thanks in advance,
Thanks in advance,
Thanks in advance,
Thanks in advance,
Thx for the info so far.
Looking at the Airaid jr vs the Full Airaid dam system. Not a fan of the factory lid removal, as mine hangs up on the lip behind and under the corner bracket around the washer fluid. But at least I'd be pulling it off less to change the filter with the Airaid system. So hard to decide....
I run the Volant filter with a Volant pre-filter to catch all the big junk and keep it out of the pleats of the oiled filter. Air tube is always squeaky clean![/QUOTE]
Looks good too. Any noticeable mpg increase?
Looks good too. Any noticeable mpg increase?[/QUOTE]
I saw a small increase, generally picks up nicer, and a bit more instant response. The noise is cool though
I improved a full 1 mpg on my Suburban running a Spectre Cold Air system. I'm hoping to do the same with this beast.
Side note;
I'll probably switch to Amzoil again which gave me an additional 1.5 - 2mpg gain on the same Suburban. I've been using Amzoil for 15 years now, and that was just the engine oil. I plan on changing all fluids to Amzoil in this H2.
Side note;
psych0
05-28-2009 01:14 PM
speedster
01-20-2008 11:35 PM
