03 H2 BCM location
Old 08-31-2012, 06:44 AM
Fireman2020's Avatar
Default 03 H2 BCM location
Ok, many electrical issues (doors locking, seat memory, etc...) is forcing me to have the BCM replaced. The catch, $300 for BCM, $1,000.00 to install, I am being told that it is due to the location of it. My idea, tear it down to that point then drop off at dealership and save 6 hours of labor cost. Just need to know where to start.
Any suggestions???
Old 08-31-2012, 03:29 PM
Rusty_03's Avatar
Fireman, unfortunatly part of the 'labor' costs is programming the module. If I read the shop manual correctly, none of the control modules come programmed.
When I was troubleshooting my 4WD problem, I found out about what it takes to swap modules. 1) the module can be programmed on a bench computer or 2) it can be programmed in the vehicle through a remote 'hand-held' from a computer. option 1 is the quickest and best because it runs diagnostics also.
If I remember correctly the BCM is in the engine bay near the hydro boost unit on the firewall. Not 100% on that, I kinda did a data dump when I was done.
I got my shop manual (2 Vol. set) from Helm Inc. The OBD system is a CAN system, so if you want to communicate with any module, you need a scanner that is GM CAN "Enhanced" enabled .
MikeH
Old 09-06-2012, 06:26 AM
Stan's Avatar
Visit to
how to program the ECU OR BCU ( BCM ) for HUMMER
Old 09-06-2012, 06:29 AM
Stan's Avatar
Old 10-04-2012, 02:08 PM
Sorry on the delay, but thanks!!!
Old 10-07-2012, 10:32 PM
DanielOlaf's Avatar
Steve #1
03-30-2019 03:49 PM
runamok
10-14-2011 08:50 AM
vmif16
07-03-2010 02:22 PM
hyposho
05-27-2010 03:58 PM
07HummerH3
07-31-2007 10:55 PM
Quick Reply: 03 H2 BCM location
