TPS. Code 21
Old 11-15-2011, 08:24 PM
logicbyondreason's Avatar
Default TPS. Code 21
Experts-
I write to you because I am still battling some issues with my H1. A quick reminder: I own a 1995 6.5 NA that was having some tranny issues. I replaced the transmission and some of the symptoms of not shifting smoothly have vanished. As recommended, I ensured the grounding points were tight and the TPS was calibrated with the required block. I am now in a scenario where I get code 21 with the tranny stuck in safe mode. I hooked up the Tech1 with the engine off and watched the TPS voltage and % jump around and never settle down. Also, after applying the throttle it seems to get stuck at 35%. Following the manuals troubleshooting instructions I have checked for voltages and shorts. One of the last parts for troubleshooting code 21 is to jump two pins on the TCM, which I did. The result did not show a voltage greater than 4.9v per the tech manual and is hinting at a bad TCM or a possible short/ground. Have you seen symptoms like that which lead to a bad TCM? Can a TCM be tested at a dealer? Where can I buy one? How much are they? Any suggestions/tips? Part numbers? I do not have any wiring diagrams for the truck except the one for the transmission. Any help would be appreciated. Thank you in advance.
Very Respectfully,
Pavel
Alex2012
10-01-2012 01:53 PM
Oni
01-30-2009 04:17 PM
dantstk
01-06-2009 02:35 PM
triplej2k6
10-27-2008 12:28 PM
HummerGuy
04-13-2008 05:17 PM
Quick Reply: TPS. Code 21
