Aluminum body, rust
Old 12-17-2007, 01:11 PM
Mastiff's Avatar
Default Aluminum body, rust
So, what parts of the H1 are aluminum and what parts are steel? Which areas are prone to rust? Thanks!
Old 12-17-2007, 01:40 PM
HumminNBoatin's Avatar
Default RE: Aluminum body, rust
From what I know the whole body unit is made of Aluminmum.
Old 12-17-2007, 01:50 PM
ronb's Avatar
the roof and doors are steel (d.o.t. regs.) The body is alum. I hear the roof is prone to rust at the seams. Never had issues, or heard of any with the doors. Same potential problems as other vehicles underneath.
Old 12-17-2007, 04:28 PM
I have seen rust at the hinges of the tailgates and where antenae and other aftermarket items are bolted on. I have also seen corrosion ( not rust ) on the aluminum bodies.
Old 12-17-2007, 11:35 PM
thehammerh3's Avatar
wow I barely hear anything about rust on h1's, but I guess when I upgrade to it I wont pass on the dealers body warranty ha.
Old 12-17-2007, 11:48 PM
Don't worry about rust. They do much better than almost anything else.
Old 12-18-2007, 01:18 AM
Injunfarian's Avatar
Rust is due to the 2 different metal types joining together if you get an Open top you dont have to worry about this. could always op for a Calgold top later and no worries either as long as the hardware you use is aluminum. since calgold tops are.
Old 12-19-2007, 08:12 PM
hmcoleap's Avatar
As others mentioned, the roof and doors are steel. Tailgate hinges are aluminum, no rust worries there.
The aluminum body can suffer from oxidation, which can cause the paint to bubble up, but it won't eat away at the body like rust does - it will just make a chalky looking buildup.
Xtreme
Private 'Wanted' Classifieds
09-12-2023 06:51 AM
hmer
16
07-17-2017 09:24 AM
LoJac963
09-27-2013 11:48 AM
studio theater
05-23-2007 07:51 PM
Arkie 355
12-10-2006 11:38 PM
Quick Reply: Aluminum body, rust
