1993 H1 Cummins 6bt conversion with rebuilt original tranny is slow
Old 06-23-2013, 11:31 AM
Rojolo's Avatar
Default 1993 H1 Cummins 6bt conversion with rebuilt original tranny is slow
Greetings everyone. I purchased a project Cummins 6bt conversion with a trashed original th400 transmission. I just finished the transmission rebuild and attaching the custom driveshaft so i took it out for a drive and hit a whopping 40 mph Is this normal for this transmission or is something wrong. It is shifting smoothly, so I have a feeling a new transmission is in my future if I ever want to drive it on the highway.
Any info would be appreciated.
Old 07-04-2013, 07:10 AM
The TH is a 3 speed transmission. With factory gearing and the TH400 the original 6.2 will do 65-67 but it won't like it. 55-57 is my normal highway speed in the 92. With the Cummins you should have more power so duplicating the OEM performance should be easy. If you want to 70-75 on the highway a 4L80 and regear are in your future.
Old 09-03-2014, 11:17 PM
Rojolo's Avatar
Update.
Well, I have been busy. I put in a 47RH tranny behind the cummins with a NP241DHD transfer case so I can select 2wd/4wd. I have it set up so I can manually switch the overdrive and torque lock up at my leisure. I has been working very well since adding 4000 fuel pump governor springs (over the top - I know) which was preventing me from going faster than 55 mph - now i can go as fast as I want!
I can now pull my military M105 trailer loaded without difficulty. Now to insulate the beast as I cannot drive it on the freeway without earplugs.
cheers
tavion2378
Hummer H1
21
08-11-2019 08:34 AM
JCsh2
05-05-2013 09:24 AM
Tonio
11-08-2012 06:54 AM
MiddMackAttack
07-08-2012 11:51 AM
katoom250
04-06-2012 11:20 PM
Quick Reply: 1993 H1 Cummins 6bt conversion with rebuilt original tranny is slow
