h2 just died
Old 05-07-2011, 09:20 PM
thenderson's Avatar
Question h2 just died
was driving down the freeway about 65 when my hummer just died. I have power but it wont crank. I noticed a car lock icon on the dash. any ideas?
Thanks.
Old 05-08-2011, 04:43 AM
Draketh's Avatar
Thanks.
Sounds like the security system shut the engine off. Pretty sure the H2 doesn't have a chip in the key, because the H3's don't either. My friend buys, repairs, and sells salvage vehicles, and he was using a hardware store key.
Usually, at least on my H3 when the ignition gets locked, it starts back up after about ten minutes, and like your issues, won't crank. Did you eventually get it started again?
No idea what would have caused it while going down the freeway. Hell of a time for your security module to go bad if that's what it is.
Old 05-08-2011, 01:30 PM
thenderson's Avatar
going to pull it to the dealer tomorrow. I checked everything I could think of, but no luck. Something is keeping power from the starter and engine for sure, but have power to everything else. I'm just glad I wasn't in the middle of no where like I was the week before. Thanks for your input.
Old 05-09-2011, 08:38 AM
Draketh's Avatar
Yeah, I've heard of this happening with the H3 a bit. I think most times it was either the security module or the body control module going bad and triggering the lockout.
Old 05-09-2011, 10:25 AM
You might try disconnecting the battery for about 10 minutes and see if it resets.
Old 05-13-2011, 09:19 PM
thenderson's Avatar
fuel pump was shorting out and blowing a main fuse. Thank you.
tyler durden
10-12-2011 10:32 AM
thenderson
05-22-2011 10:42 AM
indyh2
02-01-2008 05:01 PM
HumV
34
07-20-2007 10:58 AM
Sugardaddy
08-18-2006 11:23 PM
Quick Reply: h2 just died
