1992 hummer H1, 6.2 diesel injector pump and injector issues
I have 1992 6.2 non turbo diesel hummer h1 which I am rebuilding totally. I had engine remanufactured and changed injection pump. Instead of factory Stanadyne DB2829-4979 10154615, I installed brand new military Stanadyne DB2829-4879 10149634 wich I converted to 12 volts from 24 volts. Now the question is will it work? and WHICH INJECTORS SHOULD I USE? Factory injectors are LONG BODY which I believe open at 129 or so BARR? ANY ADVICE ON THE MATTER OR AM i MISSING SOMETHING?
Ian Ward! thanks for reply. however I have engine out of the car and I want to make sure I put the right stuff inn, before putting it back. From what I read from forum is that unless you match pump, injectors and lines perfectly, you will have smoke and power issues. Also that plastic thing where wires connect is busted and I dont know even how its called or what type I need so I can order it from ebay or other place. I live in Europe and because international delivery takes very long time and is expensive, I have to be perfectly sure before I order something.
Regards,
Beso
Regards,
Beso
Ronpintx
10-26-2015 04:44 PM
Chitimacha
06-27-2014 12:22 PM
