Clear DRL Tutorial w/Pics
I realize we have a running thread on this subject but I think it has lost some steam.
You can do this mod with the tires turned in for access but if you remove the wheel it becomes amazingly easy. (damn our tires are heavy!).
Start out by removing all the push pins. There are about 12 in each wheel well. You need a screw driver and needle knose pliers.
The Wheel well liner pulls out easily.
This gives you access to the rear of the DRLs. They are help in place with 3 small self tapping screws. A nut driver is the easiest tool to use to remove these. The DRL assembly now floats inside a cradle but can't be removed from the rear. If you have a brush gard like I do it has to be removed also. This meant I had to loosen the Tow hooks for removal.
You have to pop the hood and remove one nut on each side that holds the upper grill. This will allow you to pop each end of the grill. You don't need to remove the gril but simply pull the ends out for clearance.The grill isvery flexible but you really have to bend it for clearance of the DRL assembly.
After you have removed the DRL assembly you can replace the OEM bulb with an amberSavania Silver Star.
Reverse the order and button everything back up.
Here's my end results. I reused the OEM DRL bulb.
CAN YOU SEE ME NOW!!!
RE: Clear DRL Tutorial w/Pics
Nice write up, Vader. As I mentioned in the other thread, I didn't have to remove the wheel but maybe as I started with a nut driver and long extension on the ratchet so it wasn't hard to reach.
ORIGINAL: alrock
I think all the lights being clear looks a lot betterplus offers more continuity and works well with chrome.
ORIGINAL: Dennis
I agree..On your front end especially, the chrome and clear looks good!..You need the fog Bezels to top it all off nicely.
Here is some chromed aluminum
http://www.xccessory.com/dwxs-h3ppc05003.html
and here is the ones I got...EBAY
ORIGINAL: Dennis
