P0101 MAF Code
Old 06-27-2008, 12:43 PM
Gooch's Avatar
Default P0101 MAF Code
So ever so often I get the check engine light come on. Pull code and thats what I get. Sometimes, if I let the truck sit over night it clears itself in the morning. I took it to the dealer, they said whomever owned the H2 before me had a cone air filter but never removed the adapter after putting back the oem filter. The tech removed the adapter and "cleaned" the MAF and cleared the code. Guess what? The code and light is back so I have to go back to the dealer...yet another Saturday morning spent at the dealer. Any ideas on what to suggest to the tech to look for?
His words exactly "I can almost gaurantee you thats whats throwing the code". Obviously he was wrong, although they did say they would credit me for the $187 I paid him to fix the problem. Do you think a new MAF sensor will remedy the problem? Any advisce, experience?
Oh BTW the light usually gets triggered when its hot outside after hard acceleration or when passing
Thanks to yall
Old 06-27-2008, 01:14 PM
Default RE: P0101 MAF Code
Could be a bad MAF, or could be caused by K&N oil migrating downstream and collecting on the MAF electronics. I'd be a bit worried since he "cleaned" it, he may have done more harm than good. There are a few other sensors that could cause this code, like a bad MAP, but that's unusual. Did you get a P0102 too? Water in the aircleaner will cause these codes too.
Does the MAF still have the screen in it?
Old 06-27-2008, 01:28 PM
P0101 Mass Air Flow (MAF) System Performance
This is the catch-all code for MAF problems
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
These two codes will get thrown when water hits the MAF
Old 06-27-2008, 01:46 PM
HumminNBoatin's Avatar
I would put a new MAF in it yourself. They are usually pretty cheap and easy to replace. Also check for any vacume leaks.
Old 06-27-2008, 02:01 PM
Gooch's Avatar
ORIGINAL: Hummer Dog
No P0102 and yes it does still have the screen
Old 07-01-2008, 09:51 AM
Gooch's Avatar
Follow up. $270 later for a new MAF sensor, things seem to be working out...no more check engine lights thus far....now to get them to credit me for the initial $187 they charged me for not fixing it the first time.
Alex2012
10-01-2012 01:53 PM
mallesham hb
01-22-2012 07:17 AM
HummerKid82
06-12-2008 01:48 PM
dizzy
32
04-01-2008 04:41 PM
dizzy
10-27-2007 11:09 PM
Quick Reply: P0101 MAF Code
