HELP! oil leak on top of steering gear box or transmission/steering line?
Old 02-06-2008, 05:16 PM
SafariHummerH2's Avatar
Default HELP! oil leak on top of steering gear box or transmission/steering line?
I noticed that the top of my steering gear box is wet with oil. However I beleive it's the transmission oil cooler line or is that a steering hose line? which runs directly over on top of the steering gear box and goes into the radiator and at that particular area of the steering box on the hose it appears wet as well. I gave all the bolts on the steering gear box a good tug with a ratchet and socket and nothing budged, indicating that all the bolts are tight. Could it be that the hose is sweating or leaking? Or the steering gear box is faulty?
Old 05-31-2016, 07:34 AM
madmike's Avatar
Banned
Old post with no replies but for future reference.... sounds like the oil cooler lines. They are prone to leak. I used a block off plate. I also developed a leak in the left side oil pan. This tends to be a big problem with these motors.
Old 06-01-2016, 10:04 AM
Please do not make a habit of digging up OLD as dirt threads for "future reference".
Thank you in advance.
Old 06-01-2016, 10:35 PM
madmike's Avatar
Banned
Please mind your own business. We are here to help each other out. Hummer brand is a dying breed and we need all the help we can get. Next time think before you post genius.
Old 06-09-2016, 12:12 PM
H2CANEPADESIGN's Avatar
Mad Mike, Can you Enlarge your avatar please?
nncanfarelli
08-04-2019 09:27 PM
lockup7
04-05-2016 04:33 PM
Eddie Omegax
03-15-2016 09:56 PM
Seventhmoreno
01-16-2016 10:46 PM
palmxjjsi
08-30-2011 12:09 PM
Quick Reply: HELP! oil leak on top of steering gear box or transmission/steering line?
