H2-Anyone rebuild their front differential? Looking for tips
Old 05-01-2011, 09:24 PM
Edelbroke's Avatar
Default H2-Anyone rebuild their front differential? Looking for tips
2003 H2 -My front diff was damaged due to being run dry, (to what extent still unknown) I've been searching for a used unit to swap in but there pretty pricey.
I've found alot of different rebuild kits forsale all for around $200 or less.
Here's one: Car Part Wholesale - Auto Parts and Accessories Catalog - Timken Differential Rebuild Kit Drk324a - For 2003
Has anyone on here had one of these apart? Any tips on the procedure would be great. At this point im going to pull it and try and rebuild it myself.
I may be dreaming here but is there a way to make this truck not all wheel drive? I'd love to have a 2HI option. AWD with 4:10 gears is crazy.
Just a thought...
Old 05-01-2011, 11:56 PM
drtom's Avatar
Banned
no i never did it. some opinions; i dont see gears in the kit?
replacing gears is very critical,spacing,it aint just a bolt in
a good used one,the easiest way out.
4.10 rear?, the 3.7,i5 is 4.56!.
the big tires demand a gear to turn them.
i didnt believe it till i figured the entire ratio,engine,tran,od,rear,tires. it takes a big gear!
it aint ez like a ford 9 inch
Old 05-07-2011, 03:59 PM
Edelbroke's Avatar
I got the differential out today. Removal wasnt as bad as I thought it would be.
By looking through the large plastic screw in plug I can see that the gears are damaged.
Anyone know how the case comes apart? I've removed all the bolts, but somehow the axle shaft plates have to come out. Are they pressed on?
Old 05-07-2011, 06:20 PM
drtom's Avatar
Banned
i would do some reading about rebuilding diffs. u should get the impression that its not a job for the average good mechanic, so have it done or get a used one,,,or invest in the experience
Old 05-16-2011, 04:48 PM
luda81's Avatar
theres probably couple of snap rings and stuff in there.
Old 01-19-2012, 10:33 PM
esterling's Avatar
Were you able to find a source for a good used front differential for your 2003 H2? Unfortunately, I am in the market for one now...
rijowysock
04-04-2013 10:03 PM
conrad
07-02-2011 04:51 PM
rallyrcr
06-18-2010 08:52 PM
dwaxman1
04-27-2008 08:18 AM
WOLFGANGSTA
41
01-30-2007 12:04 AM
Quick Reply: H2-Anyone rebuild their front differential? Looking for tips
