H3 X no start issue need help
hello and thanks for any help you can give me. First of all. I am very green when it comes to anything involving an automobile and fine know a lot but enough. I recently acquired a 2008 H3 X Hummer. It’s Beautiful. But one problem. Here is the scenario. The thing will start right up if it’s been sitting for a while no problems. After a tenure drive of 10 minutes or longer , the car will not start. The security light stays on solid red along with the check engine light. And it will stay on like this until it randomly wants to start again. After reading a couple threads. I have now gotten this beast to start after a tenured drive of 45 minutes by swapping out the fuse relay switch on the engine fuse box. So far , I have down this twice with a different fuse every time ,and it starts. While I was trying to start this truck yesterday and waiting before I realized to swap out the fuses. In the auxiliary on positio. The voltage is fluctuating because I have a super car charger that displays the voltage on it and it was going up and down , but when the car was not having Any issues or was running the colts we’re not fluctuation This could be totally random but I thought I’d mention it. It’s not a passlock issue because that security light is not blinking which I didn’t know at first because a relearn does nothing for this issue. What would cause the fuel relay to get tripped to not work after the truck is running for some time but swap it out and it will work to turn in the pump and I can drive. Has anyone experienced this and is so what is my next step in diagnosing the problem here and how do I do it.
thanks so much and I hope my post makes sense.
You need to post ONE Thread and be patient, we are not your instantaneous fix my Hummer personal website!
Do a search, you have a passlock issue. Google GM Passlock............. Many times it is caused by poor/dirty ignition switch connections, which is an easy fix. Somebody?????????????? made and posted the pic below.
Search it here too.
Search it here too.
Mistake
Search it here too.
Search it here too.
Good luck.
Reason I don’t believe it’s a padlock issue .
I had a lock smith check out the car when it would not start up. He could not relate it to a relearn issue. The security light stays illuminated along with the check engine light accompanying it , only when the no start issue is happening. I have not been in a situation where I can check to see what code this is when I’m stalled , since it’s intermittent , narrowed this down to when the engine becomes warm , and when I finally do check it , there is no light illuminated , and the system doesn’t even show a record of the light ever being on . Which is so weird . Per the technical bulletin I read , if it were a passlock issue , security light would become illuminated but be blinking off and on. I will start it upon cold and it starts up every single time , it will even start back up right away even after shutting it off , but in a couple minutes or 15 minutes later it won’t start back up for 2 hours , approximately . In this 2 hours . When you turn the key to start , you can hear the fuel pump turn on but there is absolutely no crank at all. Silence almost. It is the most annoying issue I have ever dealt with on a vehicle. Thanks again for your help
Heatherlp9
01-05-2022 01:17 PM
Heatherlp9
01-05-2022 01:15 PM
