remove factory stereo instructions for H3?
Old 12-08-2006, 04:41 PM
maximuss32's Avatar
Default remove factory stereo instructions for H3?
Does anyone have any diagrams or photos that show how to remove the factory stereo on a 2006 H3? Or how to get to the XM module?
Old 01-14-2007, 11:32 AM
Default RE: remove factory stereo instructions for H3?
To remove the factory stereo, you have to remove the center dashboard console. This console just snaps in and out, so all you need to do is pop it out. I removed mine using the following method:
1. Look for the two DC power ports on the bottom right of the center console. Open the covers.
2. Using a pair of pliers and a piece of cloth (to prevent scratching), stick each side of the pliers in each hole. Squeeze and pull gently. The console should pop out on the bottom right.
3. All you have to do is slowly pull out the console after that.
This website also shows you how to do it, although that guy used his fingers instead of a pair of pliers:
http://www.rausite.com/hummerh3.htm
Can't help you with the XM radio. I don't use mine.
Old 01-14-2007, 11:43 AM
blackstangs281's Avatar
Welcome tvoltero. And thats a good "how to do site"
Old 01-14-2007, 03:59 PM
either put your pointer and middle finger in the 12v. plug holes and pull out the radio bezel or take a plastic spoon and starting at the top right corner, slowly pry out the bezel working your way around the entire unit.
The XM is behind the glove box area I believe.
Old 01-27-2007, 12:59 AM
WHERE DO YOU GET THAT KIT SO YOU CAN KEEP THE ON-STAR!
Old 01-27-2007, 06:20 AM
mountainbiker's Avatar
I cannot speak from first hand experience but have a look at
http://www.logjamelectronics.com/
http://www.jpcustoms.com/ **
** I have spoken to these guys on the phone. They were really, really helpful and nice.
jobenshain
01-24-2014 11:07 PM
Alukavi
03-19-2009 07:20 AM
foozed
07-29-2008 11:45 AM
DILLIGAF08H3
05-20-2008 09:45 PM
timtran
07-18-2006 10:28 PM
Quick Reply: remove factory stereo instructions for H3?
