Hummer H2 Radio Loom or Bose Amp Details
Old 01-17-2008, 09:08 AM
Mad Professor's Avatar
Default RE: Hummer H2 Radio Loom or Bose Amp Details
Just been thinking wile I have got most of the dash out, I might as well fit a new Head Unit.
What is involved with fitting a Head Unit with a standard ISO wiring?
I can see from the above that I have, Battery Feed, Ground, Front Left, Rear Right,pins in the standard hummer radio loom.
But the pictures above does not show Front Right & Rear Left, and also does not have switched feed, but that can be taken from the fuse board neer the pedels, But what about the bose amp, will that just power up when it see's an audio input, or does it need some other sort of feed?
Thanks again for your time.
Old 01-17-2008, 10:11 AM
ORIGINAL: Mad Professor
depends what headunit you want to install...I pu a Kenwood DDX in and had to use a Metra GMOS o4 interface.....it was plug and play...... check
www.crutchfield.com
they have all kinda stuff to hook up aftermarket headunits for H2
Old 11-26-2008, 09:23 PM
thanks i was looking for stuff like this
Old 04-02-2009, 01:21 PM
vital velocity's Avatar
Any reason why the pictures of the wiring harness do not show for me?
Old 04-18-2009, 06:49 AM
Carcrazy's Avatar
Banned
it is easy to get to as most of the hummer is in bit's, wile tracking down power drains.
ISrt300
03-15-2017 09:36 AM
mrigor
07-09-2013 11:08 PM
desiyaar1
09-26-2009 09:17 AM
merry
01-05-2009 12:07 AM
RedRocker
05-03-2007 07:19 PM
Quick Reply: Hummer H2 Radio Loom or Bose Amp Details
