GM OEM Navigation Radio for my 2003 H2
Old 09-12-2007, 01:17 PM
Hummster's Avatar
Default GM OEM Navigation Radio for my 2003 H2
I bought a brand new GM OEM Navigation Radio for my 2003 H2. I am checking to see if anyone has some installation tips or instructions for this. I wondering if there are any tips or tricks that I should be aware of. Just some FYI as many of you all know Hummer didn't start installing the Navigation into the H2 i believe until 2006. I contacted my local dealer and they inform me that a new OEM navigation system should install with no issues as long as it was the GM PART# 17801147. I wondering if any others have installed this kit in older models H2 with success. I'm curious to know where you installed GPS antenna?
Thanks in advance
Hummster!
Old 10-26-2008, 04:02 PM
Default RE: GM OEM Navigation Radio for my 2003 H2
Did you get the navi system to work in your 03 H2? I want to do the same thing to mine.
Old 11-07-2009, 07:05 PM
RDRAGE's Avatar
Default Oem navi
Hey, i also bought a brand new oem navi, having problem. Radio does not want to function wth the amp. All hummer h2 has bose system and all hv lux. So does any1 hv any similar problem's.
Old 11-08-2009, 08:52 AM
calif phil's Avatar
I put a 2006 nav unit in my 2003 h2. I bought a used unit and a new XM module from GM. I installed the GPS ant and XM unit under the right side of the dash just like where the factory mounted them. The ony trouble I ran into was the GPS wouldn't work until I ran a speed senor wire from the dash to nav connector. It was a lot of work but it was worth it. I would not hesitate to do it again.
agood1
04-24-2020 12:31 AM
usmc3521
06-18-2013 06:24 AM
SundownAudioNY
09-06-2011 03:02 PM
tperk
07-21-2011 06:21 AM
crank
06-15-2007 12:05 PM
Quick Reply: GM OEM Navigation Radio for my 2003 H2
