Back Up Camera ??
Back Up Camera ??
I posted this in the "H2" section but maybe this is the proper place:
I just ordered the Navtool Interface to add Back up Camera to my 05 H2. I have rear mounted spare tire carrier. I need input on best location to mount camera. Upon searching, I found the following locations:
1. Center Marker/Clearance Light. I like the looks of this location but couldn't find what camera was used or if a mount is available to replace the light.
2. License Plate Mount. Mine is in center of Spare Tire Carrier.
3. Bumper above receiver..
4. Inside vehicle top of rear hatch..I think my rear glass is to dark for this mount..
Would like to get suggestion on which camera (Brand,model) and where you mounted..
Thanks in advance..
Thanks in advance..
I'm adding a second rear camera on the rear licence plate. I currently have a hitch cam (oem) but it's not enough so have bought a rear licence plate surround with the built in camera. I can't add pics from my phone right now but it should tuck just under the chrome part of the tyre carrier cover.
Actually I managed to do it.
Here's the front mount am having done also for tight parking spaces (I live in the center of Moscow)
I believe when I put it in reverse the oem hitch cam will work in the mirror as normal, the rear number plate will also work on the head unit screen. I can press aux input on the head unit to see the front camera. Hope it helps!
Aggiedad04
06-07-2018 03:28 PM
TexasNative83
12-17-2011 05:56 PM
bogy
08-18-2006 10:17 PM
